1999 Mazda 626 Mazda 626 Transmission
103,000 MILES • 4 CYL • 2WD • AUTOMATIC
JDUNLAP44
The vehicle has recently started to "buck" some at lights. I should have taken it to get checked, however did not. After struggling up a snow covered hill this weekend, I found the car would only operate in 2nd gear and then only occasionally. I am almost certain I have killed the transmission, however wanted to see if there are any other possibilities as it is not worth replacing / rebuilding.
Dec 21, 2009 at 2:39 PM
  • 31,937 POSTS
Hi there, thank you for the donation,
I does sound rather terminal, but it is wort getting a scan done just to see if it an electrical issue, and a trans specialist can do a test & report and this will give you a definitive answer on that question.. is it worth repairing.
mark (mhpautos)
Dec 21, 2009 at 4:06 PM
