Mazda 323f problem
KHD
  • 5 POSTS
Hi I have recently bought a Mazda 323F a few months ago, it has now 72200 miles year is 1995 and is a 1.5GXI. recently when I am driving and change the gear from 1st to 2nd it starts to jerk as though its misfiring this repeats the process in 3rd gear also but not in 4th please help as my car had been serviced in June when I bought this.
Many Thanks
Sep 21, 2007 at 7:41 PM
  • 75,988 POSTS
[quote:851eefc011="khd"]Hi I have recently bought a Mazda 323F a few months ago, it has now 72200 miles year is 1995 and is a 1.5GXI. recently when I am driving and change the gear from 1st to 2nd it starts to jerk as though its misfiring this repeats the process in 3rd gear also but not in 4th please help as my car had been serviced in June when I bought this.
Many Thanks[/quote:851eefc011]
When was it last major tune-up?
Sep 21, 2007 at 7:52 PM
KHD
  • 5 POSTS
Hi Thanks for getting back apparently it had its service 2 weeks before I bought it in June this year.
[quote:ae92fdd677="rasmataz"][quote:ae92fdd677="khd"]Hi I have recently bought a Mazda 323F a few months ago, it has now 72200 miles year is 1995 and is a 1.5GXI. recently when I am driving and change the gear from 1st to 2nd it starts to jerk as though its misfiring this repeats the process in 3rd gear also but not in 4th please help as my car had been serviced in June when I bought this.
Many Thanks[/quote:ae92fdd677]
When was it last major tune-up?[/quote:ae92fdd677]
Sep 22, 2007 at 7:50 PM
  • 75,988 POSTS
Does it have a rough idle in Neutral position. If not could be the clutch slipping.
Do this at 1st gear ease on out on the clutch and when it gets to the point when you normally release it, kick on the gas if revs up high before it reacts its slipping. Maybe a free play/height adjustment if not then its time for a clutch assy.
Then again it might be coming from the electronic engine controls-
Try checking for an exhaust back pressure to rule the exhaust system-Hence Catalytic Converter.
Sep 22, 2007 at 8:05 PM
KHD
  • 5 POSTS
Thanks for your advice really appreciated, I have just one more problem when I am moving away in first gear when the car is stationery or when reversing I can hear like a ticking sound coming from behind. Please advise what this can be.
[quote:f7d56155bb="rasmataz"]Does it have a rough idle in Neutral position. If not could be the clutch slipping.
Try checking for an exhaust back pressure to rule the exhaust system-Hence Catalytic Converter.[/quote:f7d56155bb]
Sep 23, 2007 at 7:32 PM
  • 75,988 POSTS
could be something loose -check the exhaust system or look for an exhaust leak
Sep 23, 2007 at 9:18 PM
KHD
  • 5 POSTS
[Thank you have given this into the garage for diagnosis will keep you posted to see what the outcome is
Thanks
could be something loose -check the exhaust system or look for an exhaust leak[/quote]
Sep 23, 2007 at 10:29 PM
KHD
  • 5 POSTS
I have been told the ticking is because I need a new back box on my exhaust.
Sep 27, 2007 at 7:15 PM
