1995 Mazda 323 Miss fire
1995 MAZDA 323
116,000 MILES • 6 CYL • FWD • MANUAL
SIDEMANTIES
My car broke down a few months ago and I replaced the distributor cap and rotary arm. She miss fires at low revs, high end revs and if I attempt to accellerate too fast. She struggles to pull off and will take a few attempts to build revs to p[ull off.
I have been reccomended to replace the MAF meter/sensor which I have done but we still have the same problems.
Are you able to offer any advice plaes?
Aug 26, 2009 at 7:14 AM
2CARPRO JACK
  • 11,533 POSTS
Have you replaced the plugs and plug wires? The computer will have a hard time adjusting mixture if the basic tune up isnt in good working order
Aug 26, 2009 at 7:43 AM
SIDEMANTIES
I have recently serviced the car and had plugs replaced and cables checked!
Could you reccomend some other parts to replace?
Aug 26, 2009 at 3:13 PM
2CARPRO JACK
  • 11,533 POSTS
Could be injectors.Pull the plugs to see if any one looks a different color than the rest.May even be a partially restricted exhaust, try loosening the pipe where it bolts to the manifold and see if it runs better, if so the cat converter is probably bad
Aug 26, 2009 at 3:37 PM
CURMETT
hey man, does it idle fine? might pay to have someone check the vaccume advance. (as was the problem with my misfiring)
Sep 18, 2009 at 11:45 PM
