1994 Mazda 323 Will Not Start
Cosmo...Mazda Tech
I would lean towards a distributor though
Suggested Repair
Confirm the replacement distributor is the correct 323 unit and not a similar-looking Protege distributor. Check spark quality: blue spark is acceptable, orange spark is too weak to start the engine. Also inspect the igniter under the ignition coil on the driver side of the engine compartment (three-wire connector, about the size of a matchbox), since igniter failure can look like a distributor problem. The expert leans toward a distributor issue.
Conversation Summary
A 1994 Mazda 323 hatchback stopped running after losing distributor signal. Spark briefly returned during distributor work, then the no-start returned. A junkyard distributor was installed, but the car still will not run despite spark, about 50 psi fuel pressure, acceptable compression, and no PCM codes. The timing belt is loose, though timing appears correct. The expert advised verifying a 323-specific distributor rather than a Protege unit, checking whether the spark is blue or weak orange, and considering the igniter, while leaning toward the distributor as the cause.
