Other Category problem
1989 Mazda 323 4 cyl Two Wheel Drive Manual 237K miles
A small hose behind the engine (near the firewall) is leaking radiator fluid and needs to be replaced. How best to replace this hose? From above, I can barely reach it and it would likely require removing a lot of stuff. From below I can reach it, but it is still very tight and I'm not sure that I can get at it with tools in-hand. Any suggestions? I thought it best to get some advice first prior to starting on this project. Thanks.
Jan 8, 2008 at 10:34 AM
