2004 Mazda 3 shakes and wont start
RJHORNER
  • 2004 MAZDA 3
  • 4 CYL
  • FWD
  • MANUAL
  • 89,000 MILES
My car recently started to shake very violently and almost felt as if it the wheels or the engine were going to fall off and when I was coming home the day after it started to shake it just quit and now wont even start. What would the problem be?
Sunday, December 6th, 2009 AT 9:09 PM
Lets do below might lead us somewhere and get back
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard
Sunday, December 6th, 2009 AT 10:02 PM
