The system need to be evacuated then the compressor needs to be removed. And then you can remove the screws that hold the clutch on and replace in the reverse, you can buy some "RTV" to give the new clutch xtra sealing power along with the new gasket
SPONSORED LINKS
Saturday, May 15th, 2010 AT 1:59 PM
