Master and slave for clutch
1995 JEEP CHEROKEE
225,000 MILES • 2.5L • 6 CYL • 4WD • MANUAL
JRS74656
  • 9 POSTS
Saturday I was unable to shift down or shift into reverse while the engine was running. I could only shift up by revving the engine. I smelled a burning smell. I took it to my mechanic, he said the fluid had leaked out of the master/slave cylinders. He replaced the cylinders but said there was some air that would bleed off after a few days (no bleeder valve). Sunday I was having just as much trouble shifting as I did on Saturday. Any thoughts on possible causes or on the bleed-off issue would be greatly appreciated.
NOTE: It is a 4.0L, not a 2.5L. I selected incorrectly.
Mar 4, 2018 at 11:39 AM
  • 31,937 POSTS
the burning smell sounds as if the clutch is slipping, if the drive is taken up with the pedal well up off the floor the clutch may well be slipping. do you have good pedal pressure with the clutch pedal or is it soft and has a lot of free play?
Mar 4, 2018 at 5:44 PM
JRS74656
  • 9 POSTS
The pedal pressure was fine before the cylinders were replaced. It seemed softer after.
Mar 4, 2018 at 8:32 PM
  • 31,937 POSTS
could still be air trapped in the system, where is drive felt? how high is the pedal? have you done a stall test to see if the clutch mechanical's are okay?
Mar 5, 2018 at 4:33 PM
JRS74656
  • 9 POSTS
Turns out there was still air trapped in the system. Had to be manually bled off by pumping the clutch.
Mar 5, 2018 at 9:04 PM
  • 31,937 POSTS
Okay, you are all under control then. come back here any time you need assistance.
Mar 6, 2018 at 4:05 AM
