Hello, I have a problem with a MAP sensor for the car listed above, engine 1G-FE. when I drive the car at fifty km per hour and above it vibrates a lot, but when I lift my feet the throttle car is stability or comes back normal. Also, when the car is running at idle speed when I move the MAP sensor with my hand slightly turns off the engine. What is a fix of MAP sensor and how to clean it at home? please help!
Apr 11, 2018 at 12:25 PM
