Lower ball joint
136,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
FALCON5098
  • 9 POSTS
Bought a new ball joints and did not fit. How do I get the ball joint into the lower control arm without damaging the control arm? I think there is slightly over sized to compensate for wear. Any help would be appreciated. thank you.
Aug 26, 2017 at 6:21 AM
CARADIODOC
  • 34,414 POSTS
The ball joint is bolted to the lower control arm with two bolts. Are you saying those bolts are too fat?
Aug 26, 2017 at 1:28 PM
FALCON5098
  • 9 POSTS
No,the shaft will go in the control arm. In about 1/3 and that's it.
Aug 28, 2017 at 6:17 AM
CARADIODOC
  • 34,414 POSTS
Any chance you can post a photo? The only thing I can visualize is the control arm is bent, making it impossible to fit the ball joint into it.
Aug 28, 2017 at 11:31 AM
