Low fuel pressure?
200,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RODPOD
On a cold start it will crank up then go shut off. Like it's not getting enough fuel. Can hold the accelerator down when it cranks up for a few seconds and after that it will stay running. Every time after that initial start it will crank up and run fine.
Sep 22, 2024 at 12:35 AM
  • 110,244 POSTS
The fuel pressure could be dropping off. Here is what I need you to try and let me know the results.
1) Turn the key from off to the run position (engine off) and count to 5
2) Turn the key off and repeat step 1 a total of 5 times.
3) On the 6th time, see if it starts normally.
Let me know the results. Also, if you have access to a live data scan tool, check what the coolant temperature sensor is indicating before starting it cold.
Sep 22, 2024 at 1:17 PM
