Low fuel pressure
2002 ALL OTHER MAKES ALL OTHER MODELS
30,000 MILES
ALESSANDRO1254
Dear Sir,
I have a generic question to ask, doesn't relate to a car but to a motorbike, but I belive that the basic technic is the same.
My fuel system does not manage to get the right pressure while priming, neither while idling or running on 6000 rpm. The pressure, according to suzuki should be 42 psi but it constantly stay at 37 psi.
Fuel pump works correctly, so watching your video about fuel pressure regulator I tried to disconnect the vacuum line while idling and suddenly the fuel pressure shots up to 42 psi.(right pressure)
Is the regulator to be faulty or is too much vacuum going on in there?Can I use the bike with vacuum line still disconnected?
Thanks for the help you would give me
Alessandro Roscioli
Apr 24, 2013 at 5:54 AM
  • 31,937 POSTS
The modulator is working , with vacuum off it should go up, is the vacuum supply ported of direct manifold vacuum, it should be direct manifold vacuum and at idle be about 18-21" Hg
Apr 24, 2013 at 7:41 AM
