Low coolant warning light
2005 MAZDA RX8
71,000 MILES • 1.3L • 3 CYL • 4WD • MANUAL
STEF GREEN
Why after flushing radiator and refilling fluid the low coolant light stays on?
Oct 20, 2017 at 8:30 AM
HARRY P
  • 2,292 POSTS
Did you bleed the air out of the cooling system when you refilled it? If not, air in the system could be your problem. Also, make sure that your coolant reservoir is also full.
Here is a guide: https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
The bleeding process is basically laid out in step 5.
Oct 20, 2017 at 12:20 PM
