Have replaced both front pads and rear shoes. Bled brakes numerous times starting at the right rear an moving around vehicle ending at left front. The bleeders are above the brake lines. There seems to be no difference when the engine is running to when it is turned off. The brake pedal will actually bottom out.The rear brakes shoes are dragging. Pumping the pedal helps slightly.
Mar 14, 2016 at 8:16 AM
