Loud popping sound when cut wheels
STEVE W.
  • 13,577 POSTS
That can do it. Good job. I would probably check it after a couple days, if it was loose once it could get that way again. If it does, you may want to put some loctite on it then torque it down.
Friday, April 19th, 2019 AT 4:26 PM
CORY2427
  • 288 POSTS
I would be afraid to take the whole bolt out never get it back in probably. I called dealer and ordered two of that bolt just in case it did it again. I just replace them don’t know what there post to be torque to, but I torqued it to 110ft lbs.
Saturday, April 20th, 2019 AT 1:13 AM
STEVE W.
  • 13,577 POSTS
The only info I can find on the subframe says they get tightened to 70 nm plus 180 degrees so about 50 ft lbs then a half a turn from that. I suspect you are in the right area at 110.
Saturday, April 20th, 2019 AT 5:40 AM
