Lost of total power
100,200 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
ROBERT FULWIDER
While car shuts completely off, lose all lights in dash, no brakes steering, put over into park and starts back up.
Apr 22, 2021 at 12:19 PM
  • 110,248 POSTS
The first thing I would recommend is checking the alternator output. Here is a link that explains how to do it. All you need is a voltmeter or multimeter.
Let me know if this happens slowly or all at once everything is off. Also, are there any electrical components that continue working?
Apr 22, 2021 at 1:27 PM
ROBERT FULWIDER
The alternator was checked and found good. No power to anything at all. pull over put in park and starts right back up.
Thanks, Bob
Apr 23, 2021 at 2:29 AM
  • 110,248 POSTS
Hi Bob,
This is going to be a tricky one without scanning the can-bus. CAN stands for controller area network. Basically, all the modules/computers are tied together via a few wires. Scanning the CAN will identify any areas of issue.
As far as this condition, I have my suspects, but I can't be sure without the scan. On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle, the PMM is the instrument panel module (IPM). I'm questioning if it is failing.
So, to save time and money, I recommend having the can scanned. Here is a video showing how it is done:
https://youtu.be/InIlnsjOVFA
If possible, have that done so we can determine if there are codes specific to the IPM.
Let me know what you find.
Apr 23, 2021 at 10:52 AM
