Problum starting and runs real ruff
134,000 MILES • V8 • FWD • AUTOMATIC
PATRICKME
My sts when I start it and this is very random it will run so ruff and lack of power it barely pulls away from the curb. If I sit and wait and nurse it trough the motor lag by increasing RPM slowly it will stop missing and run normal. If I start it 10 times in a day it might have the issue 4 times. Every few days when I go to start it if I'm in a hurry and try to rush it when it's missing it will die and then not restart. I do have an engine light on had it checked and it says motor is running lean I pulled the plugs and replaced them and the did look like the motor is running lean.
Dec 7, 2014 at 9:42 AM
  • 110,251 POSTS
I need the code. As far as a lean mixture, usually it is caused by a vacuum leak, weak fuel pump...
Dec 7, 2014 at 12:20 PM
