HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
All
Engine
Symptoms
Low Power
Loss of power when driving up hills and flat areas
MICKEISHACROSS
MEMBER
2005 NISSAN
4 CYL
2WD
AUTOMATIC
160,000 MILES
Loss of power on hills and flat areas. Vehicle fuel consumption is too high.
Sunday, October 23rd, 2016 AT 12:55 PM
HMAC300
MECHANIC
Scan for codes and check fuel pressure with a gauge auto parts rent it but you may need an adapter for that. see link.
SPONSORED LINKS
Sunday, October 23rd, 2016 AT 2:47 PM
Please
login
or
register
to post a reply.
Related Engine Low Power Content
Problems With Starting
I Have Had The Coil Pack Replaced, The Gasket Covers Replaced, The Spark Plug Wires Replaced, Oil Changed, And The Ignition Thing Under...
Asked by
Brittany Crawford
1 ANSWER
2005
NISSAN
VIDEO
Fix an Engine with Low Power!
Instructional repair video
GUIDE
Symptoms of Low Engine Power
The power your car's engine is producing is important. When you step on the gas you need your car to accelerate, mainly to keep you out of trouble when getting onto the...
Does Not Start
I Ran Out Of Gas Then L Put Some In, But Now It Does Not Start.
Asked by
Filo Mendez
1998
NISSAN
Car Will Not Stop After After Switching Off Or In The...
This Model Ad Started Problem One Day Where It Failed To Generate Enough Power To Climb Even Small Hills, We Decided To Change The Engine....
Asked by
Beckham Kim
1 ANSWER
2008
NISSAN
Transmission And Start Problem
My Vehicle Will Not Go Into Reverse. It Drives Slow With Speeds Just Up To 60 Mph. It Does Crank, But Then It Shuts Right Off. The Vehicle...
Asked by
Margie Hunter
1 ANSWER
1999
NISSAN
New Cylinder Heads
What Is The Torquing And Tightening Procedures And Specs For Cylinder Heads On A 2004 Ford Ranger Edge 3.0 Liter V-6.
Asked by
Kirby Bennett
1 ANSWER
2 IMAGES
1990
NISSAN
VIEW MORE
SPONSORED LINKS
Catalytic Converter Test
Online car repair manuals
