Loss of power after cam belt replaced
200,000 MILES • 1.6L • TURBO • 2WD • MANUAL
ASK+LEARN
Hi, seeking some advise on an issue I have as the mechanics at the garage seem to be stuck on solving the issue. To make it short cam belt snapped while driving at an average of 40 mph had it taken into garage and replaced only now it is running again but very slow on acceleration. now turbos working maybe only slightly working not sure but seems to be extremely slow when driving. the guys in the garage are convinced the valves remain straight and not bent after the belt snap due to the car starting and running first time. each time no hesitation any suggestions on what may of occurred or has been overseen that may solve this issue and bring the acceleration back to life? new belt and pulleys apparently have been replaced correctly apparently, but they seem to be stuck on the issue why the throttle is so slow when the turbo is still actually working. any help at all will be fantastic.
Dec 20, 2018 at 11:54 AM
  • 110,246 POSTS
Honestly, it sounds like they may not have correctly timed the engine. If the timing is off, it can affect exhaust pressure which in turn will affect the turbo. Also, a timing issue will cause power issues.
Interestingly, I am only showing a 2.0L engine for this vehicle so I don't want to send information if it is wrong. Please confirm the year and engine size.
Thanks,
Dec 23, 2018 at 10:55 AM
