Leaking antifreeze?
107,000 MILES • 6 CYL • 4WD • AUTOMATIC
DMCM
antifreeze leaks from somewhere near the front passenger tire about 8 to 10 inches in.
Mar 22, 2021 at 1:18 PM
  • 110,248 POSTS
The water pump is there. Do me a favor. Take a look through this link and let me know if you are able to locate the leak. Note, the link has several possible leaking locations. If you page down to number 5, it discusses the water pump.
https://www.2carpros.com/articles/car-is-leaking-coolant
If you are still unable to locate the leak, then I would recommend pressure testing the cooling system. This is done with the engine cold and requires a pressure tester. Most parts stores will lend one to you. Here is a link that shows how it is done:
https://www.2carpros.com/articles/radiator-pressure-test
Let me know what you find and I'll direct you on the repair required.
Mar 22, 2021 at 2:01 PM
