Loses power then sputters and shuts off
290,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JENNIFER WHEAT
Okay, here's the gist of it: One day after cutting the vehicle off and then go to crank up to leave, nothing. Thought it was the battery, so I get a jump. Cranks but soon shuts off right after wards. Get second jump, car loses power the starts to sputter and shuts off. Figured it was out of gas (needed some in it anyway) put gas in still same thing. Every time it gets cranked it idea shortly after and drains the battery every time. What is it?
Jul 21, 2020 at 9:09 PM
This sounds like a fuel issue so we need to rule that out first. Here is a guide on how to check fuel pressure. Let's check the pressure first and go from there.
If I understand the issue properly, when the vehicle shuts off does it crank and not start or when you turn the key the engine does not even spin over? If it doesn't spin over then this is not a fuel issue.
Let me know what the fuel pressure is or a little more detail on what the issue is and we can go form there. Thanks
Jul 22, 2020 at 8:45 AM
JENNIFER WHEAT
I have to get it jumped off via jump box or another vehicle, but once it loses power then shuts off I can't crank it again. It attempts to but the battery has no juice.
Jul 22, 2020 at 12:06 PM
Okay. Let's start with testing the battery and alternator to make sure we are starting with a sound charging system.
Based on this info, I suspect we have an issue with the alternator. However, this depends on how long after the battery was replaced it drained again. Either way, we need to confirm the battery and alternator are okay and go from there as a severely drained battery will cause these issues. Thanks
Jul 22, 2020 at 12:19 PM
