Check applicable codes. If your fully obd1 compliant, you can check codes yourself. How long since a tune-up? Any electrical sensor, if there is a problem on the wiring circuit, replacing the sensor won't fix it. Also, you could disable the fuel system, use a spark tester on each plug wire, one at a time, engine cranking, see if you have spark at all plugs. If you have spark everywhere, use a gage and check fuel pressure.
Friday, August 23rd, 2019 AT 1:35 PM
(Merged)
