1994 Lincoln Town Car Overheats in Traffic
COLANTUONO
1994 Lincoln towncar 4.6, 120,000 miles
it overheats in bumper to bumper traffic, but is fine long as traffic is flowing. changed thermostat , but it still does it. does not lose any fluid, just heats up and rings the bell, and the temperature gauge goes up, when we start moving again it goes back down to normal.
thank you so much
Jeff
Feb 28, 2007 at 2:31 AM
BHUGG
  • 157 POSTS
If the car has an electric cooling fan. Make sure that it works. The fan should come on when the engine gets hot. Check fuses. There are 2 fuse boxes, one in/under the dash and one under the hood. It might even have a relay that could fail.
If that is OK, you might have a failed water pump.
feedback is important.
Good luck.
Did this help, give a vote.
Feb 28, 2007 at 4:45 PM
Suggested Repair
Verify the electric cooling fan comes on when the engine is hot, and check both fuse boxes plus any fan relay. If the fan circuit is good, suspect a failed water pump.
Conversation Summary
A 1994 Lincoln Town Car with a 4.6 engine overheats in bumper-to-bumper traffic but returns to normal once traffic moves. The thermostat was replaced and no coolant is lost. The expert advised checking the electric cooling fan, fuses, and relay, and considering a failed water pump if those are okay.
