I have a 1995 Lincoln Towncar Signature series, 196,000. When I turn my headlights on, my clock turns off. Any ideas?
Aug 26, 2006 at 2:41 AM
Check the dash dimmer switch first, since the clock and dash lights dim when the headlights are on and can be brightened with the dimmer. If the dimmer is working, inspect the fuse panel for blown fuses that could affect the clock.
The owner of a 1995 Lincoln Town Car says the clock turns off when the headlights are turned on. The expert recommends checking the dash dimmer switch first, then inspecting the fuse panel for blown fuses.
