1992 Lincoln Town Car Alarm Goes Off
Activate the door lock switch 5 times in ten seconds
and count the led flashes. if it flases only one time the door disarm is OK, any more than once and there is trouble. If your not good with testing anti-theft and other ciciuts...take it for service!
When you want to lock the car try doing it from outside with the keypad, press buttons 7 and 9 at the same time. It sounds to me like the key sensor tho...
Suggested Repair
Check the key lock sensor: with the key in run, the LED should be off. Cycle the door lock switch five times within ten seconds and count LED flashes; one flash means door disarm is OK, more indicates a fault. Lock from outside using keypad buttons 7 and 9 together. If anti-theft circuit testing is unfamiliar, have the system serviced.
Conversation Summary
A 1992 Lincoln Town Car with a factory alarm sounds the horn and flashes the lights about 5 to 15 minutes after parking when the doors are locked, but not when left unlocked. A dealer said the alarm could not be disconnected. The expert advised checking the key lock sensor and LED, running a lock-switch flash test, locking from outside with keypad buttons 7 and 9, and seeking service if anti-theft testing is unfamiliar.
