abs system
CHRCHEF
  • 6 POSTS
I have a 1992 Lincoln Towncar Cartier series 4.6 l vehicle. Have had new front brakes put on the car as well as new emergency brakes and cables. When the brakes are applied the car stops quickly and grabs so hard that it tries to throw you out of the seat. Removed abs fuse and the problem goes away. This was the reason new brakes were put on as they said it was caused by bad rotors on the front. it shows no error codes when the fuse is inserted. Thanks for your help
Apr 6, 2007 at 8:30 AM
  • 75,988 POSTS
[quote:8650f237ba="chrchef"]I have a 1992 Lincoln Towncar Cartier series 4.6 l vehicle. Have had new front brakes put on the car as well as new emergency brakes and cables. When the brakes are applied the car stops quickly and grabs so hard that it tries to throw you out of the seat. Removed abs fuse and the problem goes away. This was the reason new brakes were put on as they said it was caused by bad rotors on the front.[/quote:8650f237ba]
Have them pull the ABS diagnostic code/s
Apr 11, 2007 at 11:58 PM
CHRCHEF
  • 6 POSTS
There are no codes when the fuse is in.
Apr 12, 2007 at 8:29 AM
