1999 Lincoln Town Car Condesation drain line location
1999 LINCOLN TOWN CAR
100,000 MILES • V8 • 2WD • AUTOMATIC
XCBRVN68
No water is coming out from under the car when the A/C is being used. I suspect a clogged drain line. However, I've been under the car, concentrating on the passenger side front wheel area, and I cannot find it. Where is the drain line located?
Thanks for your help.
May 30, 2008 at 4:55 AM
MASTERTECHTIM
  • 4,750 POSTS
its located at the firewall down low. its easier to see from underneath car. is the water coming into vehicle on floor?
May 30, 2008 at 4:59 AM
XCBRVN68
[quote:891ad76eac="mastertechtim"]its located at the firewall down low. its easier to see from underneath car. is the water coming into vehicle on floor?[/quote:891ad76eac]
Thanks for directing me to the possible location of the drain line outlet. to answer your question, no, there is no water anywhere. The line is not draining at all. That is what I think is causing the A/C not to cool properly.
May 30, 2008 at 9:58 AM
