Both turn signals don't work. No turn signal lights on dash or outside front or rear. The left multi switch lever on steering column operates turn signals, emergency warning flashers, wipers and high beams. Wipers, emergency warning flasher, and high beams all work fine from this l same ever, but not either turn signal. Fuse for turn signals checks out okay. Rear back up and brake lights work fine.
Is there a separate flashing unit for turn signals on this car that might be out and if so, where is it on this car? Is the problem the turn signal multi switch, even though other functions for this switch work well?
Tuesday, September 7th, 2010 AT 8:08 PM
