1995 Lincoln Town Car (ABS) NOT WORK
1995 LINCOLN TOWN CAR
186,250 MILES • V8 • 2WD • AUTOMATIC
EHAB
Dear Sir
I HAVE TOWN CAR 1995 WHENE I AN START THE ENGINE THE (ABS) LIGHT TURN ON AND ABS NOT WORK IF YOU CAN GIVE ME THE WAY TO TEST THE (ABS) AND FIND THE EROR BY MANUALY METHOD.
B.REGARDS
EHAB
Jul 20, 2008 at 11:40 PM
RICK 08
  • 54 POSTS
Hi: i am not a mechanic however
For what its worth..
I have solved an ABS problem with a Ford..
All wheels have a sensor as I expect you know, if you can use a ohm meter you could trace each sensor to a quick disconnect and compare readings, all should be about the same, Each sensor generates a voltage for a given RPM. in my case the ohm reading alone on one sensor was way out compared to the others and the problem was resolved by replacing the sensor...
Jul 29, 2008 at 5:18 AM
DJFINESSE80
  • 34 POSTS
4 PROPER ABS BRAKES REPLACE THE SENSORS. 2 MANUALY TEST. ON DRY SURFACE, DRIVE AT 35MPH, THEN SLAM ON THE BRAKES , THE WHEEL THAT LOCKS UP HAS THE BAD SENSOR, OR BAD ABS COMPONENTS
https://images.2carpros.com/forum/automotive_pictures/218559_m_bfac118db97d5095beff1f53f16e3594_7.jpg
Jul 29, 2008 at 9:46 PM
