1994 Lincoln Town Car Air Suspension
1994 LINCOLN TOWN CAR
OSCARBROWN
Has over 200,000 miles. having problem with fuses in Air Suspension system having to replace daily. After replacing fuse, car lifts to normal height, but for some reason it blow the fuse. I replace it and the same thing happens. Where do I start looking for the problem? Where is the suspension compressor located?
Sep 22, 2007 at 7:20 PM
RODE KIL
  • 5 POSTS
[quote:a864ef557e="oscarbrown"]Has over 200,000 miles. having problem with fuses in Air Suspension system having to replace daily. After replacing fuse, car lifts to normal height, but for some reason it blow the fuse. I replace it and the same thing happens. Where do I start looking for the problem? Where is the suspension compressor located?[/quote:a864ef557e]
The compressor is normaly under the hood.
Try using a higher amp fuse.
Sep 23, 2007 at 12:49 AM
OSCARBROWN
[quote:b615cb37c2="Rode Kil"][quote:b615cb37c2="oscarbrown"]Has over 200,000 miles. having problem with fuses in Air Suspension system having to replace daily. After replacing fuse, car lifts to normal height, but for some reason it blow the fuse. I replace it and the same thing happens. Where do I start looking for the problem? Where is the suspension compressor located?[/quote:b615cb37c2]
Try using a higher amp fuse.[/quote:b615cb37c2]
It takes a 30amp fuse and any higher amp is too big in size. Could it need resetting or something
Sep 23, 2007 at 5:56 AM
