1989 Lincoln towncar fuel injectors
1989 LINCOLN TOWN CAR
DADSHOTROD
I have a 1989 Lincoln Towncar with 98K miles. I want to change my fuel injectors, but I don't know how to remove the top (gray) cover to access the fuel rails. How many bolts? Where are they? Any other hints to changing the injectors would be greatly appreciated. It has a 302 engine
Apr 21, 2006 at 11:23 AM
LOSONE
  • 1,616 POSTS
Those injectors are bullet proof. Why do you want to change them??
Apr 21, 2006 at 11:28 AM
DADSHOTROD
[quote:fd179cee64="losone"]Those injectors are bullet proof. Why do you want to change them??[/quote:fd179cee64]
2 of them showed bad on an engine systems check.
Apr 21, 2006 at 12:06 PM
LOSONE
  • 1,616 POSTS
Run a double dose of injector cleaner through the gas tank as see if they do a little better. Does the engine misfire?
Apr 22, 2006 at 12:24 AM
