Suspension problem
1998 Lincoln Mark VIII V8 Two Wheel Drive Automatic
Hello, I was working on my 1998 Lincoln Mark VIII and had it up & down on block's several time and i thought i had the air ride switch off but it wasn't off but i shut it off before i took it down. Now it pump's the front bag's all the why up and i get a code of Check air ride. They don't leak i had to replaced the passenger side one with a used one but haven't had it on the road sence i change it. I could use some help with this problem so i can get it on the road it has been sitting for about 5 year's THANK YOU.
Sep 15, 2010 at 8:24 AM
