2003 Lincoln LS PO353, PO355, PO356
2003 LINCOLN LS
BILL GAMBLE
Electrical problem
2003 Lincoln LS 6 cyl 99652 miles
car came in with these codes, replaced #3,#5,#6 coils (NAPA) no better. checked and thought coil wasn't grounding but in retrospect it may have been too dim for me to see. sent computer to FL to get fixed and reprogramed no better removed inj. and all were firing while cranking. fuel pressure was 35lbs and compression was 125lbs on #5 (easiest plug to get to.)it seems like engine runs smooth for about 5 seconds when you first crank it also seems to run smooth when doing KOER test although engine is running about 1600 rpm. local Ford dealership has car and run all tests to no avail also talked with Ford repair also replaced coils with ford brand no better you can remove coil and plug and ground plug and it fires great. put it back in hole and it makes no difference in engine performance. bill
Sep 23, 2010 at 3:28 AM
DOCFIXIT
  • 18,828 POSTS
Hi
My thoughts are fuel pressure to low leading to missfires.Fuel system pressure is controled by Fuel Rail Pressure sensor. Need a scanner that can read PRF/PIDwhile observing fuel pressure raise rpm to 2500.Pressure shoul be within 5psi of Max.
3.0l 55 psi
3.9L 65psi.
Also know to have broken wire in coil pack connector wiggle if engine smooths out repair.
Let me know
Thanks for donate
Check missfire in history codes see what cylinders are most common
Sep 23, 2010 at 6:48 AM
