2004 Lincoln LS Engine is mission with OBD II Code P0358
2004 LINCOLN LS
80,000 MILES • V8 • 2WD • AUTOMATIC
JEPARADY
The OBD II Code of P0358 says :Ignition Coil H Primary/Secondary Circuit Malfunction". Which cylinder is represented by "H"?
Apr 12, 2009 at 5:42 AM
JAMES W.
  • 2,394 POSTS
Going over my reference material, the nearest I can tell is cylinder "H" is #8 in the firing order. I have nothing to prove this other bits and pieces.
Apr 12, 2009 at 1:02 PM
JEPARADY
It turns out that "H" is number 7 in the firing order. Don't ask me why, but replacing the number 7 coil solved the problem.
Jun 7, 2009 at 6:07 AM
