The problem with p0171&p0174is the center spacer of the intake maniofold .the gaskets get oiled and brittle and cause a small vacuum leak. ford will sell you an updated spacer, clean all oil and you will be good to go. check pcv!!!!!
If plenum and lower intake are removed, check the rubber elbow between the pcv vapor separator and the metal pipe that comes out behind the upper corner of the left head. The elbow may be sucked closed in the bend and have a small hole. The part number is 3W4Z-6767-CA, available at your local Ford dealer.
1. HO2S sensors are not likely to be the cause of adaptive DTCs P0171, P0172, P0174, P0175: Most warranty-returned HO2S sensors (replaced for these DTCs) are found to function normally. Additional related DTCs will normally be present if there is a concern with the HO2S sensors. Do not replace an HO2S sensor unless verified through pinpoint diagnostic tests found in the PC/ED Service Manual. 2. DTCs P0171, P0172, P0174, and P0175 are not related to downstream HO2S sensors: When diagnosing a vehicle with a MIL On and DTC(s) P0171, P0172, P0174, and/or P0175 in continuous memory, do not replace the downstream HO2S sensors. These DTCs have no connection to the downstream HO2S sensor function nor its diagnosis for faults. Always verify the vehicle concern, then perform the pinpoint diagnostics from the appropriate PC/ED Service Manual. 3. Diagnosing lean conditions and lean DTCs P0171, P0174: Freeze Frame Data can often help to identify the type of lean condition, even if the fault is intermittent, by indicating how the vehicle was being driven when the fault occurred. Diagnosis of lean conditions and lean adaptive DTCs can be difficult, especially if the concern is intermittent. Verifying the concern is extremely important. There are different types of lean conditions. The ability to identify the type of lean condition causing the concern can be crucial to a correct diagnosis. When DTCs P0171 and P0174 are both present, there is a strong likelihood of another concern being present: a. Vacuum leaks/unmetered air: In this type of condition, the engine may actually run lean of stoichiometry (14.7:1 air/fuel ratio) if the PCM is not able to compensate enough to correct for the condition. This condition is typically caused by air entering the engine through an abnormal source (opening), or due to a MAF malfunction. In this situation, the volume of air entering the engine is actually greater than what the MAF is indicating to the PCM. Vacuum leaks will normally be most apparent when high manifold vacuum is present, during idle or light throttle. If Freeze Frame Data indicates that the fault occurred at idle, a check for vacuum leaks/unmetered air when the engine is cold might be the best starting point. Examples: Loose, leaking or disconnected vacuum lines, intake manifold gaskets or O- rings, throttle body gaskets, brake booster, air inlet tube, stuck/frozen/aftermarket PCV valve, unseated engine oil dipstick, MAF reading lower than normal, etc. b. Insufficient fueling: In this type of condition, the engine may actually run lean of stoichiometry (14.7:1 air/fuel ratio) if the PCM is not able to compensate enough to correct for the condition. This condition is typically caused by a fuel delivery system concern that restricts or limits the amount of fuel being delivered to the engine. This condition will normally be most apparent when the engine is under a heavy load, when a higher volume of fuel is required. If Freeze Frame Data indicates that the fault occurred under a heavy load, a check of the fuel delivery system (checking fuel pressure with engine under a load) might be the best starting point. Examples: Low fuel pressure (fuel pump, fuel filter, fuel leaks, restricted fuel supply lines), fuel injector concerns, etc. c. Exhaust system leaks: In this type of condition, the engine may actually be running near stoichiometry (14.7:1 air/fuel ratio), but the exhaust gas mixture will be lean. This condition is caused by oxygen-rich air entering the exhaust system through an external source. This condition will cause the exhaust gas mixture to be lean, even though theactual combustion in the engine may not be. Examples: Exhaust system leaks upstream or near HO2S, malfunctioning Secondary Air Injection system. d. MAF concerns: If a MAF concern is suspected, see TECHNICAL SERVICE BULLETIN 98-23-10 . 4. Checking fuel pressure: Check fuel pressure with engine under a load when diagnosing a lean concern. A partially plugged fuel filter can be difficult to detect and can be easily overlooked if fuel pressure is only checked at idle. The same is true for other types of fuel supply concerns (e.g., bent or kinked lines, degraded fuel pump). At idle, an engine requires only a small volume of fuel. Due to the fact that there is a small volume of fuel needed at idle, a restriction in the fuel supply line in many cases will not cause the fuel pressure to be low. When the vehicle is under a load, the engine requires much more fuel than at idle. Under a load, a restriction in the fuel supply line will prevent the high rate of fuel flow that is needed to maintain the correct fuel pressure.
11/25/2009
http://www.ondemand5.com/mric/common/asp/Article.aspx?MOD=TSBART&YEAR=2 ...
Nov 25, 2009 at 4:42 AM
