I have a 2000 lincoln LS that had the same problem. I've replaced 6 out 8 ignition coil packs on it so far. The problem is once one goes the others go shortly after. Best best is to replace the ignition coils and plugs while you're at it (considering the mileage) and hopefully this will take care of your issue. Dealer cost per coil is between 90-115 but your local parts store has it for around $50, just may not have a lot or any in stock. Should be able to order though.
SPONSORED LINKS
Saturday, February 9th, 2008 AT 12:55 PM
