2000 Lincoln Continental Rear Piston Won't Retract
ALANSKI
2000 Lincoln Continental....I replaced the front brake pads and rotors with no problems.....I'm doing the rears now but I can't get the piston on the brake caliper to retract to fit the new pads. I put the c-clamp on it and openned the bleeder, but it won't bugde....what am I doing wrong?
Nov 15, 2007 at 11:08 AM
BMRFIXIT
  • 19,053 POSTS
[quote:7af8608f5b="alanski"]2000 Lincoln Continental....I replaced the front brake pads and rotors with no problems.....I'm doing the rears now but I can't get the piston on the brake caliper to retract to fit the new pads. I put the c-clamp on it and openned the bleeder, but it won't bugde....what am I doing wrong?[/quote:7af8608f5b]
they dont work the same way the front do
you have to turn the piston as you pushing in
they have a tool for it
good luck
Nov 15, 2007 at 12:33 PM
Suggested Repair
Rear caliper pistons do not push straight in like the fronts. Rotate the piston while pressing it in using a rear brake caliper piston tool.
Conversation Summary
The owner of a 2000 Lincoln Continental replaced the front brake pads and rotors without trouble but could not retract the rear caliper piston with a C-clamp even with the bleeder open. The expert explained that rear pistons must be turned while being pushed in and that a special tool is used for this.
