I have a 94 Lincoln Continital 3.8 liter engine with 202000 miles and the question is I am not getting nothing but cold air blowing out even after changing a bad heater core and a new water pump and thermostat and sensors and the digital display control and so called heater control and I am wondering if there is one particular damper door that can switch from cold to hot and if so where is it located.
SPONSORED LINKS
Friday, November 30th, 2007 AT 3:11 PM
MERLIN2021
MECHANIC
Don't know if this will work on 94 but try hitting off and floor at the same time, then within 2 secs hit auto, if 25 comes up it's the blend door sticking or the actuator.
