HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Lincoln
Continental
Ignition
Spark Plug
Replace/Remove
1998 Lincoln Continental
MIGHTYJOE61
MEMBER
1998 LINCOLN CONTINENTAL
V8
FWD
AUTOMATIC
17,000 MILES
I have a bad mis-fire on random cylinders I replaced the spark plugs and checked the wires. What other areas should I look at.
Sunday, March 1st, 2009 AT 3:17 AM
MERLIN2021
MECHANIC
Check fuel pump pressure, and when you checked the wires, What was the resistance? Check injectors should be 11-18 ohms, check IAC hook positive lead to the white/red wire of the harness connector and the neg to ground terminal of the iac. should be 6-13 ohms. Fuel pressure should be 35-55 with key on engine off.
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
SPONSORED LINKS
Sunday, March 1st, 2009 AT 6:58 AM
Please
login
or
register
to post a reply.
Related Spark Plug Replace/Remove Content
Lincoln Contineal
Replace Spark Plugs
Asked by
ajeffri3
1 ANSWER
1998
LINCOLN CONTINENTAL
VIDEO
Spark Plug Gap
Instructional repair video
GUIDE
Spark Plug Replacement
A spark plug is a vital part of the engine's ignition system and is responsible for starting the combustion process. As a part of an engine tune up, spark plugs should ...
Changing Plugs
How Do I Get To The Set Of Spark Plugs Up Against The Firewall On 94 Lincon Continental 3.8 Liter.
Asked by
jerseywayne
1 ANSWER
1994
LINCOLN CONTINENTAL
Replace Spark Plug Wires
I Can Buy Spark Plug Wires For My Lincoln From Around $85 To $140. What Is The Difference? Same Question For Spark Plugs Ron
Asked by
halltrade
1 ANSWER
5 IMAGES
1997
LINCOLN CONTINENTAL
1998 Lincoln Continental Cylinder Identification
Engine Mechanical Problem 1998 Lincoln Continental Front Wheel Drive Automatic Where Is The Number 3 Cylinder On A 12998 Lincoln...
Asked by
qwerty123456
1 ANSWER
1998
LINCOLN CONTINENTAL
1997 Lincoln Continental Spark Plug Wire Setup
1997 Lincoln Continental V8 Two Wheel Drive Automatic Hey Guys I Need A Diagram Or Picture Or Anything On Where The Spark Plug Wires Go...
Asked by
frank777
1997
LINCOLN CONTINENTAL
VIEW MORE
SPONSORED LINKS
Spark Plug Replacement Honda
Spark Plug Replacement Mercedes Benz C230
Spark Plug Replacement - Chevrolet
Online car repair manuals
