1997 lincoln continental
1997 LINCOLN CONTINENTAL
IYZERE
I have a 1997 lincoln continental that was towed and the suspension was not cut off. The rear suspension appear to be full of air. I do hear the air compressor coming on but the rear of the car is sitting pretty high. How do I fix this problem?
Feb 18, 2006 at 2:33 AM
LOVESCARS
  • 359 POSTS
The towing facility should have flat bed the vehicle anyone that has dealth with these suspensions should know this. You may be able to go after the tow company for screwing your suspension up.
The air pressure is always adjusting for load conditions it's likely the pressure control was messed up??? Need to have a mechanic diagnose
Feb 18, 2006 at 7:55 AM
