AC not getting cold
JIMTRAV1234
V8 two wheel drive automatic.
Hello, i have an AC problem. I think it is the electronics. I set the controls for 60 degrees fan blows. Only hot air comes out. The compressor is not cycling. No voltage to the compressor.
Jun 18, 2009 at 7:59 AM
MICKEY-D
  • 304 POSTS
First, check your fuses, there should be one for the A/C compressor. Then check voltage to the low refrigerant switch. If you have power to only one side of the switch with the A/C on, you either have a bad switch, or low refrigerant.
Dec 2, 2009 at 5:04 PM
DA_WIMP2
  • 6 POSTS
@MICKEY D. What is the low refrigerant switch? And where would it be on an 2002 Continental?
May 14, 2018 at 3:35 PM
  • 55,673 POSTS
Hi DA_WIMP2,
Please post your question here:
Cheers, Ken
May 15, 2018 at 4:54 AM
DA_WIMP2
  • 6 POSTS
Okay, sorry did not know.
May 15, 2018 at 5:22 AM
  • 55,673 POSTS
No worries. ;)
May 15, 2018 at 10:39 AM
