Any ideas???
1996 Lincoln Continental Surge Hesitation
Any ideas???
Ford recommends new O2 sensors @100,000 miles.
Check for vacuum leaks and sticky EGR valve.
Good luck and let us know. :)
Suggested Repair
Confirm whether the MAF code returns, since the MAF may be faulty. Replace the oxygen sensors, as Ford recommends new sensors around 100,000 miles; the front sensors control air-fuel ratio information to the PCM. Also check for vacuum leaks and a sticky EGR valve.
Conversation Summary
A 1996 Lincoln Continental with 210,000 miles surges or hesitates at idle and wide-open throttle, with about 7 mpg lost. The fuel pump and filter were replaced the prior year, and code P1131 was retrieved. Cleaning the MAF did not help, though unplugging it seemed to improve running slightly; a fuel flow data error appeared before starting and then cleared. The expert suggested the MAF may be bad, recommended new oxygen sensors around 100,000 miles, and advised checking for vacuum leaks and a sticky EGR valve.
