1994 Lincoln Continental Stalls on Turns
YABOYALAN
my 94 continental cuts off sometimes when making a turn or backing up. when i get to a stop sometimes it seems as if the car wants to cut off. any suggestions?
May 18, 2006 at 2:11 AM
PEPPERMRJ
  • 1,158 POSTS
Try a little fuel injection cleaner. I like chevron techron. Might be time for plugs and wires also.
Good luck and let us know. :)
May 20, 2006 at 11:00 AM
SMPAULEY
We had this problem on our 99 lincoln, I have no idea what it is called but it was this little L-shaped boot on the breather hose that was split and needed to be replaced. Was told it was a dealer item and would cost around $70. The guy at autozone replaced it with something like it (at no cost) and it was fine after that.
May 28, 2006 at 1:40 PM
Suggested Repair
Try a fuel-injection cleaner such as Chevron Techron, and inspect or replace the spark plugs and plug wires if they are due.
Conversation Summary
The owner of a 1994 Lincoln Continental said it sometimes cuts off while turning or backing up and seems ready to stall when coming to a stop. The expert suggested fuel-injection cleaner and possibly new plugs and wires. Another owner described a similar stalling issue on a 1999 Lincoln that was resolved by replacing a split L-shaped boot on the breather hose.
