Dash lights and headlights seem dim
145,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
LOU ROMANSKY
The dash lights and headlights don't seem to be as bright as they once were. I've had the system checked and they say nothing is wrong. Battery good and alternator good. Still duller than it was.
Dec 3, 2019 at 8:36 PM
AL514
  • 5,685 POSTS
Hello, there's a couple possibilities, low voltage or a bad ground wire to the body control module. This module controls all lights, blinkers etc. The only way to properly diagnose is to check is proper voltage is going in and coming out of the body control module along with voltage dropping the power and ground to the module. And checking . Personally it sounds like a bad ground wire limiting current flow to that circuit causing everything to be low. The headlights are exposed to a pretty hostile environment. For a quick check, go through the fuses to make sure a fuse isn't burned. If you have a test light, go through and check each side of each fuse still plugged in, with key on or engine running. Start there.
Dec 3, 2019 at 10:28 PM
