1999 Lexus RX 300 Starting engine trouble
1999 LEXUS RX 300
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOANN TED
I used my car in the am and 2 hours later it would start but would not stay on unless I kept my foot on the gas pedal!?
May 22, 2009 at 4:56 AM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
Sounds like it may be an issue with the Idle Speed Control Valve.Toyota/Lexus use adesign that is sensitive to carbon build up an will hang up and not idle or sometimes idle too high.It is mounted on the bottom of the throttle bore.If removed and cleaned out with carb cleaner it will ususally take care of the problem
May 22, 2009 at 7:43 AM
