1999 Lexus RX 300 Engine cuts off
1999 LEXUS RX 300
BUCK2509
Engine Mechanical problem
1999 Lexus RX 300 6 cyl Automatic 125000 miles
the engine will crank momentarily and then cut off. It won't run.
Sep 21, 2009 at 10:28 PM
BUCK2509
Is a car pro going to answer my question?
Sep 21, 2009 at 11:06 PM
LEX SO CAL
  • 27 POSTS
possible idle air control valve fail
this hapens in the morning? engine cold
Sep 21, 2009 at 11:26 PM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
So it cranks for a little bit then quits turning over? Has the battery been checked? if it stops turning and the battery is good, use a test light on the small starter wire to verify the crank signal is present
Sep 24, 2009 at 12:25 PM
