1997 Lexus ES300 Front Rotor Stuck
LEXUS
SCOTT1956
1997 Lexus ES-300 V-6
Mileage 160k
Trying to replace the front rotors. Took wheel and caliper off, but could not get the hub off. Hammered and pulled, but feels like something I've missed is holding it on.
Oct 8, 2007 at 8:50 AM
MERLIN2021
  • 17,250 POSTS
Once you have removed the Torque plate, or, caliper mounting bracket, if you can't pull it off, use a ball peen hammer and give the rotor face a few good raps, it's stuck on the rust!
Oct 8, 2007 at 10:19 AM
Suggested Repair
After removing the caliper, remove the torque plate or caliper mounting bracket. If the rotor still will not come off, strike the rotor face several times with a ball-peen hammer to break the rust bond.
Conversation Summary
The owner of a 1997 Lexus ES300 could not remove the front rotor after taking off the wheel and caliper. The expert advised removing the caliper mounting bracket and tapping the rotor face with a ball-peen hammer because rust is holding it on.
