1992 Lexus ES300 Oil Leak
LEXUS
JFOXOSAGE
Dripping oil 8-12 inches directly inside the right front tire.
1992 ES300 Lexus.
Please advise where this oil may be coming from.
Thank you for your assistance.
Joe Fox
Jun 2, 2006 at 10:06 AM
LOSONE
  • 1,616 POSTS
It sounds like it might be coming from the transmission axle seal. Check you fluid level. Also your oil filter is in that area. Don't wait too long to get it on a rack and let someone look at it.
Jun 2, 2006 at 10:28 AM
JFOXOSAGE
Thank you. I will have it checked by a mechanic.
Joe Fox
Jun 2, 2006 at 12:35 PM
Suggested Repair
Have the leak inspected on a lift. Check the transmission axle seal and fluid level, and also inspect the oil filter in that area.
Conversation Summary
The owner of a 1992 Lexus ES300 reported oil dripping 8-12 inches inside the right front tire and asked where it might originate. The expert suggested a possible transmission axle seal leak, advised checking the fluid level, noted that the oil filter is nearby, and recommended a prompt rack inspection. The owner agreed to have a mechanic check it.
