1992 Lexus ES300 Engine Knock
LEXUS
ELDOUBLEU19
i have 1992 Lexus ES300 95850 miles and while the car is idiling its has a knocking sound that is comming from the front of the engine it sounds to be coming for one of the front 3cylinder there no water in the oil, no oil leak, doesnt overheat, it just knocks and its gets louder when u raise the rpm's, i had a few people look at it they all say that a maybe one of the pushrods are loose and may need to be changed what u think should i change the rod or have the engine rebuilt. thanks for any help you can offer me .
Mar 25, 2007 at 3:46 PM
MERLIN2021
  • 17,250 POSTS
if it speeds up and slow down with throttle, it's a wrist pin or a rod bearing problem....cheaper to run as is! if the noise bothers U that much rebuild the lower end of the engine, then learn how to race!
Apr 2, 2007 at 12:36 PM
Suggested Repair
If the knock rises and falls with engine speed, suspect a wrist pin or rod bearing rather than a pushrod. Running it as-is is the cheaper option; rebuild the lower end only if the noise is unacceptable.
Conversation Summary
The owner of a 1992 Lexus ES300 reports a front-engine knock at idle that gets louder as RPM rises, with no coolant in the oil, oil leaks, or overheating. Others suggested a loose pushrod. The expert says a noise that follows throttle is more consistent with a wrist pin or rod bearing and advises running the engine as-is unless the noise justifies a lower-end rebuild.
