1995 Lexus LS400 Clicking Start
1995 LEXUS
ART ANCHONDO
I have a 1995 Lexus LS400 with engine type 1UZ-FE and 116,000 miles. My Lexus started making a clicking sound when I tried to start it much like when the battery is dead. However, I am wondering if it is the starter because it always starts if I try a second or third time. It seems as if by re-inserting the key and turning it more forcefully it starts. When it finally starts, it starts quickly and I cannot hear any dragging in the starter.
Your help will be appreciated, since it will cost about $700 to repair with parts and labor.
May 22, 2007 at 9:58 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, I know, have had the pleasure of installing a starter in your car.Need to find the trigger (small black wire) that goes to the starter. Be sure you are getting 12 volts to it every time the key is cranked, if so then it needs a starter, if not I would suspect the starter relay
May 22, 2007 at 10:22 AM
ART ANCHONDO
[quote:c888dd5c45="2CarPro Jack"]Yes, I know, have had the pleasure of installing a starter in your car.Need to find the trigger (small black wire) that goes to the starter. Be sure you are getting 12 volts to it every time the key is cranked, if so then it needs a starter, if not I would suspect the starter relay[/quote:c888dd5c45]
How do I locate the starter relay since the owner's manual does not indicate the location for relays only for fuses.
May 23, 2007 at 10:18 AM
2CARPRO JACK
  • 11,533 POSTS
Should be in the underhood power/relay center
May 23, 2007 at 11:34 AM
Suggested Repair
Check the small black starter trigger wire for 12 volts every time the key is cranked. If voltage is present, replace the starter. If not, suspect the starter relay in the underhood power/relay center.
Conversation Summary
The owner of a 1995 Lexus LS400 reports a clicking sound when starting, similar to a weak battery, but the engine starts on a second or third try when the key is turned more firmly and then cranks quickly with no starter drag. The expert advises checking for 12 volts at the starter trigger wire during cranking; voltage present indicates a bad starter, while no voltage points to the starter relay in the underhood power/relay center.
